Testing Transistors With Digital and Analogue Multimeters.
Discussion in 'General Electronics Discussion' started by HellasTechn, May 7, 2016.
  1. HellasTechn
    HellasTechn
    1,537
    213
    Apr 14, 2013
    Hello !
    I have a silly question of which the answer i am sure is simple. Why when testing transistors with DMM we put positive probe to P side and negative to N side while with AMM we go reverse (negative to P side and positive to N side) ?
    Thank you !
  2. BobK
    7,682
    1,686
    What settings are you using on the multimeters? If using a diode check setting, it should be + to P - to N, but if using a resistance setting, the opposite.
  3. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Because of the circuit in the analog meter, The red lead is negative. Doubtless this simplifies the switching.
  4. HellasTechn
    HellasTechn
    1,537
    213
    Apr 14, 2013
    I use the diode mode for the DMM and resistor mode (usually mid scale like x10 or x100) for AMM
  5. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Like @duke37 said it is because the older Analog meters have the internal battery positive feeding the (-)black lead.
    Newer Analog Meters(and AVOs) and Digital ones have it connected the conventional way positive to (+)RED.
    So for analog meters you never know before you actually test the polarity or look at the schematics of the meter.
  6. HellasTechn
    HellasTechn
    1,537
    213
    Apr 14, 2013
    That makes sense.
    Thanks for the info :)
    Have you noticed that With an analogue Multimeter you can more reliably test components like transistor's specially darlington and Fet's ?
