Testing the watermaker circuit
Discussion in 'Electronic Design' started by Glenn Ashmore, Feb 24, 2004.
  1. OK, with everyone's help (including Fred's have the watermaker control
    doing what it is supposed to do (At least in breadboard form) and am
    trying to test it out in a simulated "real life" environment. This is
    not easy to set up as I had to hook the garden hose to the diesel raw
    water intake and haul everything down to the boat. I need suggestions
    on what to else to test before I break it down.
    What I have tested so far: I am figuring that the major noise producers
    are the alternator, inverter, microwave oven, VHF & SSB. I hooked up
    the breadboard to the main breaker panel, pump clutch and boost pump and
    stretched out the remote station cables along the alternator cables.
    Then I cranked up the engine, turned on the microwave, added enough load
    to get the alternator putting out 180 amps and tried all the circuit
    functions. The only thing I noticed was that the remote pressure
    display bounced around by a few mV but not enough to worry about. Next
    I transmitted 25 watts on the VHF directly over the breadboard with no
    detectable effect. Finally I moved the remote station cables parallel
    to the SSB coax, switched to CW mode and blasted 150 watts into a dummy
    load.
    What else should I try before bringing it all back to the house?
    Glenn Ashmore
    I'm building a 45' cutter in strip/composite. Watch my progress (or lack
    there of) at: http://www.rutuonline.com
    Shameless Commercial Division: http://www.spade-anchor-us.com
  2. John Fields
    John Fields Guest
  3. John Fields wrote:
    Hmmm, probably right. I guess I will have to drape some wire along the
    shed roof. Without the mast I can't test the actual backstay antenna
    configuration.
    Glenn Ashmore
