Testing electronic components
Discussion in 'Power Electronics' started by azzzaoo6, Jun 8, 2021 at 6:36 AM.
  1. azzzaoo6
    azzzaoo6
    Tuesday
    Hi which components are not recommended to be tested while in circuit like i tested a bridge rectifier in circuit got no reading took it out and got a proper reading.
  2. Harald Kapp
    11,415
    2,619
    Without proper shielding (isolation) measures almost no component can be measured reliably in circuit. Other components usually influence your measurements.
    These measures require special equipment. Therefore in most cases it is best to remove a component from the circuit before testing. Exceptions may apply depending on the construction of the circuit.
    shumifan50 and Martaine2005 like this.
