test equipment
Discussion in 'Electronic Repair' started by [email protected], Dec 15, 2005.
  1. Guest
    Hi all,
    I have a signal which I need to measure during fabrication. The signal
    is a 2.88 MHz crystal and I need to know the signal level and
    frequency.
    A scope is a great device to do this but I really only need a display
    with frequency and signal level.
    A frequency counter would do the trick for the frequency measurement
    but can not locate one of these with a signal level indication.
    Any thoughts?
    pdrunen
  2. Signal strength < 15dBm ?
    This would work fine assuming you can use the low-impedance input.
    Otherwise, use a scope.
    http://www.tequipment.net/BK103.html
  3. Jim Yanik
    Jim Yanik Guest
    wrote in
    Get a spectrum analyzer like a TEK 2712/2714 that incorporates an accurate
    freq. counter. It will also show the purity of your signal.
  4. PDRUNEN
    You could use a shortwave receiver locked onto or near the frequency,
    use the BFO or SSB mode to beat against the signal. A PC soundcard could
    measure the frequency error. If you need to know what direction the
    error is, tune lower by 1.0 KHz and measure the difference frequency, if
    it goes below 1 KHz the crystal is drifting low, higher than 1 KHz, it
    is drifting high etc.
    Some receivers have software signal strength meters that can be
    calibrated to give you a signal level indication.
    Look at some of the ICOM receivers for PC CIV control.
    Joe
    Joe Leikhim K4SAT
    "The RFI-EMI-GUY"
    "Follow The Money" ;-P
