Tesla's Electric Car #2
R
rev dan izzo
Tesla's Electric Car #2 - 01/09/98
This file was originally posted on the KeelyNet BBS on January 31,
1993 as TESLAFE2.ASC.
This file is a Sysop commentary on the Tesla Power Box as described in
the original file TESLAFE1.ASC on KeelyNet.
These are my own thoughts on the Tesla Power Box, I welcome your
constructive comments regarding this device......Jerry W.
Decker/KeelyNet
The following are the details as removed from the file TESLAFE1 :
"The standard internal combustion engine was removed and an 80-H.P.
1800 r.p.m electric motor installed to the clutch and transmission.
The A.C. motor measured 40 inches long and 30 inches in diameter and
the power leads were left standing in the air - no external power
source!
He then went to a local radio store and purchased a handful of tubes
(12), wires and assorted resistors. A box measuring 24 inches long, 12
inches wide and 6 inches high was assembled housing the circuit.
The box was placed on the front seat and had its wires connected to
the air-cooled, brushless motor. Two rods 1/4" in diameter stuck out
of the box about 3" in length."
The mention of this experiment in a local paper kind of blew me away
but it did give "some" detail of what was in this mysterious power
box.
We know that T.H. Moray had probably the best known version of such a
device. In his case he used a special "valve" which appeared to be
basically a diode. Except this diode worked more like a Triac. That
is, any electrical wave, both positive AND negative going currents,
was picked up by an antenna and passed through this diode with minimal
loss of energy. As far as we know, this valve was based on a composite
substance with GERMANIUM as the host material.
From there it went through a tuned circuit based on vacuum tubes and
capacitors to build and discharge the energy as demanded by the load.
The tuned circuits were resonant with one or more earth or cosmic
frequencies and the vacuum tubes acted as harmonic constructive
interference amplifiers of the input signals.
We will note that Moray's resonant circuits used CAPACITORS, COILS and
RESISTORS. Experiments done during Moray's heyday showed an output up
to 50,000 Watts of high frequency energy. It is believed that the
energy was high frequency because 100 watt light bulbs burned cool to
the touch.
One other CRITICAL POINT about Moray's converter was that it would
ONLY energize RESISTIVE loads and NOT INDUCTIVE loads. This is because
inductive loads imply coils of wire which are heated more so by
HYSTERESIS (interferring electro-magnetic fields) rather than simple
resistance from the flow of current through molecular/atomic patterns.
This type of interferring field caused an energy backup and subsequent
de-tuning of Moray's generator. Since it was essentially a TUNED
device, it could not compensate for any frequency changes or
distortions ONCE TUNED. As a result, any attempt to hook up an
inductive load would cause the device to stop generating electrical
energy. To restart it, all inductive loading must be removed, the
device re-tuned and restarted.
Moray also used an unusual mode of operation for a vacuum tube in that
he operated with a "cold cathode." This did not require a heated plate
for the "thermionic emissions" deemed necessary to successful vacuum
tube operation.
There is also mention of radioactive elements in the antenna circuit
which leads one to think he might have been tuning into the continual
radioactive decay processes of nature, rather than cosmic or earth
energies.
Now to the Tesla Power Box
We will first of all note the use of an AC coil motor. This alone
tells us that the Tesla device was superior and not so dependent on
tuning as was Moray's machine which could only power RESISTIVE loads.
All universal energy moves in WAVES and so is essentially for
alternating current (AC). That is why Moray called his book "THE SEA
OF ENERGY IN WHICH THE EARTH FLOATS". The entire universe is
continually bathed in these AC energies and they cover the entire
frequency spectrum.
What intrigues the hell out of me was how Tesla could use "off-the-
shelf" vacuum tubes and other components, put them together in the
correct configuration and make it work.
Another point we should note is the list of components :
1) 12 Vacuum Tubes (70L7-GT rectifier beam power tubes)
2) Wires
3) Assorted Resistors
4) 1/4" diameter rods 3" in length
NOTE, NO CAPACITORS! The wires could have been simply for connection
or wound as coils. The 1/4" rods were either BUS BARS for power output
taps OR more likely ANTENNAS! Resonant circuits can be constructed
using several techniques. You can achieve the same effect from :
1) Resistors AND capacitors
2) Capacitors AND coils
3) Coils AND resistors
So, in the case of the Tesla Power Box, he either wound his own coils
or simply used the wire to connect the resistors with the vacuum
tubes. I am of the opinion that he used the wire ONLY for connection
and DID NOT USE COILS! I also think he used a DIODE somewhere in the
circuit in order to tap ONLY one polarity.
We have no specifications for the AC motor that Tesla used in the
auto, so we have no idea if it was single or polyphase. In the case of
a single phase motor, it only requires a single winding which projects
a magnetic field that rotates according to the increase or decrease of
the alternating current.
A polyphase (poly = two or more) motor uses multiple windings which
are fed by phased input currents that alternate in such a manner as to
reinforce each other. In the case of a 3 phase motor, the currents are
phased 120 degrees apart. This gives much greater torque to the motor
but requires 3 times the current because it uses 3 times the input
energy.
Since the box powered an AC (coil) motor, it is probable it was TUNED
to one or more frequencies, most likely polyphased frequencies.
So, if the 3" long rods were in fact ANTENNAS, we can calculate their
frequency by using the following :
(I cannot express Lambda here so we will use w for wavelength)
w = wavelength
v = velocity of propagation
f = signal frequency
a short example : w = v / f = wavelength in feet
w = 984,000,000/1,500,000 = 656 feet
f = 984,000,000/656 = 1,500,000 or 1.5 MHZ
3 inches * 4 = 1 foot
984,000,000/1 = 984,000,000
984,000,000/4 = 246,000,000 or 246 MHZ
This would indicate the 3" rods (if they were truly 3" in length and
functioning as antennas) would resonate at 246 MHZ.
Because of the parts list description, I am of the opinion that it was
a DUAL circuit. That is, 6 vacuum tubes and one 1/4" diameter 3" rod
along with assorted resistors were to pick up and "pump" ONLY the
positive going signals, while the other 6 vacuum tubes, rod and
resistors did the same for the negative going signals. Such a scheme
could either use PARALLEL or SERIAL connections of the vacuum tubes.
Since current conduction is proportional to surface area, one would
think that a parallel arrangement of the 70L7-GT rectifier beam power
tubes with all INPUTS connected to one antenna source and all OUTPUTS
connected to a common terminal attached to the load, would provide for
the MAXIMUM current flow from incoming energy waves.
The nature of these "energy waves" is the question here. Are they
cosmic rays, electrostatic, Schumann peaks, magnetic force, something
"other" or Aether flow into the neutral centers of mass as per Keely.
Vacuum tube construction takes several forms. Of these, the simplest
is two plates separated by a grid wire. When the bottom plate is
heated, thermally induced ions (thermionic emissions) are emitted by
the bottom plate. The grid can be biased by the application of voltage
to increase, decrease or halt the flow of these ions to the upper
plate.
Other forms include more plates with more grids to allow better
control of the ion flow. By proper biasing, vacuum tubes can be
operated as switches, modulators or amplifiers among other uses.
Vacuum tubes operate primarily with high voltages that control the ion
flows. Modern transistors are equivalent to vacuum tubes except that
they operate using CURRENT instead of voltage. Transistors equate to
Vacuum tubes by the following comparisons :
Vacuum Tube Transistor Polarity
Operates from Voltage Current
lower plate emitter negative - cathode
grid base neutral
upper plate collector positive - anode
In the case of the Tesla Power Box, the vacuum tube appears to
function as a "pump", collecting incoming current in the form of ion
intensification. Once this "compressed" ion field reaches a certain
density, the pump allows it to be released into the next stage of the
circuit, be it the actual load or another vacuum tube.
So if the circuit is 6 vacuum tubes in parallel, all fed from a common
antenna, outputting to a common load terminal, then the common antenna
input would feed all vacuum tubes with the same wave. This would give
the greatest CURRENT accumulation because of the EXPANDED SURFACE AREA
of the paralleled tubes.
Note, these vacuum tubes most likely operate in the "cold cathode"
mode since the heaters of the vacuum tubes were not fed by any outside
voltage to provide the heat for the more orthodox therionic emission.
If the vacuum tubes are hooked in series, then one "pump" would feed
another "pump" to get successively higher densities of electrons. This
would give higher VOLTAGES because of increased PRESSURE.
Keep in mind that electricity is much like air or water. We can think
of voltage as pounds per square inch (PSI) and current as cubic feet
per minute (CFM). That is PSI is pressure, CFM is flow.
Another analog is comparing a river to electricity. In such a
comparison, the speed of the river is the VOLTAGE or pressure while
the width of the river is the CURRENT or rate of flow.
Such a comparison shows WHY current requires THE GREATEST SURFACE AREA
for the maximum flow. Fuses function on just this principle, when the
current flows over the surface of the fuse, it creates heat. If too
much current flows, it creates too much heat causing the fuse to melt
and separate. The more surface area the fuse, the greater the amount
of current can flow, another reason to not place a penny in a fuse
socket.
So we have two antennas (1/4" diameter, 3" long rods), two sets of 6
vacuum tubes connected together by wire and assorted resistors. As the
waves of energy are collected by the 3" rods, positive on one,
negative on another, the energy builds up in the form of increased
ions in each of the paralleled vacuum tubes. As in Moray's generator,
the circuit will feed whatever load is attached as long as it does not
EXCEED the current carrying capacity of the circuit components. What
we have is an energy pumping system.
I made a drawing of the box with some idea of the circuit. My
electronics knowledge is on IC's and transistors with almost nothing
in regard to vacuum tubes so there won't be much technical concept of
the circuit per se. Perhaps after some study, either I or someone else
will come up with some testable or useable circuits.
The Parallel Version
The Serial Version
TESLAFE1.HTM - original articles
TESLCAR.HTM - another viewpoint
B
Baphomet
As far as I am aware, nobody to this day has been able to figure out, no
less duplicate, how Tesla did what he did. Teaming with Westinghouse
Electric, he is also responsible for the A.C. generator, beating Edison at
his own game of D.C. power generation.
I wish you the best of luck in your endeavors and please keep this newsgroup
informed as to your progress.
John Fields
w = wavelength
For starters,
f = v/w
where f = frequency in Hertz (cycles per second)
v = velocity of propagation in meters per second.
w = wavelength in meters
For 3" rods operating as full wave resonators,
f = v/w = 3.0E9 meters per second / 7.62E-2 meters ~ 3.94E10 Hz.
That's 3.94 GIGA Hertz, quite a bit higher than your 246 MEGA Hertz.
Also, you say:
"Vacuum tubes operate primarily with high voltages that control the ion
flows."
I can't think of a single instance where a vacuum tube is is used to
control the flow of ions internal to its structure, unless you want to
consider an electron an ion missing the rest of its atomic structure
instead of the currently accepted vice-versa definition. Moreover, in
(arguably) the most common (common-cathode) configuration, the grid
voltage used to control the plate current is not at all high. Easy to
verify, just look in any tube databook.
The rest of your "exposition" is similarly flawed (Watts is watts, and
100 watts dissipated here will release the same amount of heat as 100
watts dissipated anywhere else.) and largely hearsay, so it's hard to
believe. Do you have any hard data upon which you can build a solid
platform to make your conjecture a little less tenuous?
F
Fred Abse
What about a thyratron?
F
Fred Abse
A polyphase (poly = two or more) motor uses multiple windings which are
energy
Bullshit.
Power out = (power in - losses) irrespective of whether it's DC, single
phase AC, three phase AC, six phase AC or whatever.
Given the same efficiency, a three phase motor will consume the same
power as a single phase motor of the same rating, loaded the same.
FFS go learn some AC theory!
John Fields
I don't think so, in that a thyratron isn't a vacuum tube in the strict
sense since it's evacuated and then backfilled with a gas. The gas is
put in there to provide a ready source of electrons which can be used
for the purpose at hand, but the gas _does_ have to be ionized for it to
happen, so you make a good point.
Similarly, There are also all those ion lasers I forgot about, but I
think in both cases it's the electrons that are doing the work, as
opposed to the ions.
R
R. Steve Walz
Total anti-scientific bullshit lies meant to attract nut-money and
steal people's retirements who don't know better.
They are lies.
plate.
Thermionic emission does NOT produce "ions" just because the word
contains '-ion".
Tubes don't work from "ion flow".
Lying garbage.
R
Rick
They are lies.
contains '-ion".
Lying garbage.
Hand-waving bullshit.
There is no such thing.
Total bullshit.
-Steve
Are you trying to say you doubt the validity of some of this?
Sorry, I couldn't resist ;-)
Rick.
John Larkin
Rick.
You *don't* think a dozen 70L7's in a shoe box will run an 80HP AC
motor? My, but you are skeptical.
John
D
Don Kelly
the touch.
Strike 1. If the bulb was cool, it is because it wasn't dissipating much
light energy. If it was receiving 100 watts it would dissipate 100 watts and
be hot.
Strike 2. Hysteresis is a factor where iron cored coils are used -it is not
a case of "interfering magnetic fields" causing heating. It is a non-linear
problem and causes heating in iron cores, not the coils.
Strike 3 batter 1 out - what interfering field? you have nothing to indicate
that such occurs. However, since the device had both coils and capacitors,
it could be retuned to account for inductive loads.
2) Wires
strike 1. batter 2 - items 1 and 3 above will not make a resonant circuit.
strike 2 batter 2 No coils, no capacitances, but resonance? Can you handle
EM theory better than circuit theory?
Strike 2 second batter- single phase motors have a pulsating field and
require a means of starting- generally another winding which is phase
shifted. Only after being started will a single phase motor operate- I will
not go into the "why" here.
energy.
strike 3- batter 2 out - A polyphase motor does not have 3 times the current
of a single phase motor or use 3 times the input energy for the same output.
If its input is 3 times that of the single phase motor, its output power
will be at least 3 times as much. Please try to compare apples with
apples.
Strike 1 batter 3 -Polyphase frequencies??? Do you mean 3 different
frequencies or somehow, just the right differential phase shift as seen at
each "antenna"?
w = wavelength
strike 2 batter 3 -As pointed out by John Fields who has done his
calculations correctly, your frequency calculation is out to lunch by a
large factor (try 984,000,000/0.25).
strike 3 batter 3 Have you any idea of what 246MHz (much less 4GHz) would
do applied to a conventional AC motor? Just supposing that it could run the
motor, note that the speed is frequency dependent so an 1800 rpm 60Hz motor
(4 pole) at 246MHz would be a sight to see in the brief interval before it
became schrapnel. There is no worry about that as the motor would simply
ignore the RF.
Side retired - on the basis of nonsense statements. Remainder snipped.
M
Mark Fergerson
Decker/KeelyNet
KeelyNet isn't the most reliable source you could have
chosen...
I don't think Jerry's gonna sue you, but you really ought
to look up "plagiarism".
I've seen this article all over the Net and I still wanna
know one thing about it; what's the ORIGINAL SOURCE? It's
allegedly from a newspaper article, but what paper?
Mark L. Fergerson
T
The Captain
John
You know John, I must admit that I didn't read the original entry in
this thread in its entirety because my mind was being boggled by one
inaccuracy and physical impossibility after another.
In short, if there is an explanation for Tesls's electric car, it's
not this one.
You know, if Tesla was somehow using SHF power transmission to power
his car, one has to wonder what the effects on his own biology were.
We worry about mobile phones at much lower powers, but this must have
been like sitting in the near field of a tropo scatter transmitter!
Anyone know if Telsa suffered from wierd ailments?
However, that said, if the car worked, there must be an explanation
which IS physically possible. Whether it is usable or not is another
question entirely. As an example of the physically possible but
unusable; cooking eggs by beaming microwaves across the kitchen at
them. The eggs won't be the only things to cook!
I strongly suspect that if the car could be reconstructed today and
made to work, the environmental and biologicval hazzards associated
with it would make a lot of tort lawyers very happy. I could be
entirely wrong though, and Tesla may have had the answer to clean
motoring way back then.
However, you'll forgive me, I hope, if I don't invest in any company
formed to exploit this idea.
John (other John)
