rabbithutch
- Jun 22, 2018
- 5
- Joined
- Jun 22, 2018
- Messages
- 5
I'm a geezer (past 75) trying to learn a little about electronics. I've dabbled here and there but must admit that I know very little about the subject.
I'm trying to put a couple of units that take 120 VAC input and convert it to 2 12 VDC power circuits. I plan to use these units to power LED circuits and an electrolysis rust removal setup. I don't have the terminals that I need and seek advice on what to buy. The unit has a terminal connector block with screws calling for N, L, G input and -V, -V, +V, +V output. The width of the terminal blocks is 7.4mm and the screw shaft diameters are 3.7mm. I thought I'd use the crimp type ring terminal connectors but seem to have problems finding any that are narrow enough overall to fit within the 7.4 mm width that have an inside ring diameter large enough for the screws to pass through. The power input cord is 18/3 and I planned to use 22 AWG outputs but could use larger diameter wire. My output wire is twisted copper.
Am I trying to use the wrong type connector? If so, what should I use? . . . Forked? If ring connectors are OK, what size or specification should I shop for? M6 is too wide to fit the terminal space width but accommodates the screws. I checked online for specs on M5 and M4 which seem to OK width wise but the inner ring diameters won't accept 3.7 mm screws, unless my old eyes and feeble brain are missing something. Any help would be greatly appreciated. I can upload a pic of the terminal block if that will help. Can I do that with the Upload a File button shown on this panel?
Thanks in advance.
rh
Thanks in advance.
rh
