E
eeh
I am going to design an electronic security product. It has a 0.5A
relay which connects a green 4 pins PCB mount terminal block. The
terminal block can be of type either normal or vertical or 45 deg.
However, I feel it urgy when a housing is designed around the product.
As the screwing position and the wiruing position are in vertical.
The terminal block must always be placed outside the housing.
Anyone has similar feeling when using terminal block in his/her design?
Is there any other devices which can replace the terminal block?
Is there a type of PCB mounted termianl block which screwes and connect
wires on the same area so that it can be displayed simply by a
rectangular cut-out in the hosuing?
Thanks!
Thanks!
