P
Pandora
I know this topic has been discussed previously but I wondered if
anyone had personal experience of an application similar to mine.
I wish to monitor the air temperature (-5 to +30 deg C) at various
points in a void below the office floor. The void is normally
inaccessible, but the floor is being re-laid at the moment so I have a
"one-shot" opportunity to put the temperature sensors in place.
For each monitoring point, I plan to use National Semiconductor's LM35
three-lead temperature sensor with a 2K2 resistor in series with the
output lead. This sensor/resistor will be soldered to one end of a
two-pair screened twisted pair cable (Belden 8723) such that the output
and ground signals are carried on one pair, and the power supply will
be carried on the other pair (the two grounds will be commoned at the
sensor).
The max. length of the cable will be 5 metres (16 feet). I will power
the IC with either a 9V battery or floating 12V d.c. supply and use a
1M-impedance digital multimeter to measure the output voltage. When the
output is not being monitored, the LM35 supply will be switched off.
I require an accuracy of about ±2 deg C
Has anyone achieved good results in similar applications using the
above approach? My particular concerns are whether the capacitance of
the twisted pair cable causing an error in reading and whether the LM35
will latch up.
Do I require any bypass capacitors at the sensor end?
sensor).
will latch up.
