Felix Hoxha
- Sep 26, 2016
- 1
- Joined
- Sep 26, 2016
- Messages
- 1
I want to simulate the error resistor of a temperature sensor either Pt1000 or YSi400 and I am getting stuck at the point of how should I define this Resistor in LTspice. The value of the error Resistor is like in the flow diagram calculated and question is how can I set an error Resistor that changes value with the change of temperature. I want two different values of the error Resistor one for 40°C and one for 1°C.
If the question of what an Error Resistor can be is that I am trying to simulate the problem when we have a leak contact of the conectors or cables and the temperature will be some grade Celcius more than it really is.
I hope you understand the question and have an asnwer for me.
kind regards
Felix
kind regards
Felix
