Temperature Sensing
Discussion in 'Electronic Design' started by siliconmike, Aug 15, 2006.
  1. siliconmike
    siliconmike Guest
    I'm looking for the cheapest available Temperature Sensor IC.
    The application is to detect any abnormal heating in the circuit casing
    and in this case turn self off.
    So accuracy etc. is not needed.
    Any advise will be greatfully registered.
    Mike
  2. Tim Wescott
    Tim Wescott Guest
    2N3904
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    "Applied Control Theory for Embedded Systems" came out in April.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. Try Kilxon thermostats, formerly made by Texas Instruments
    see: http://www.sensata.com/products/controls/thermostats.htm
  4. Tim Auton
    Tim Auton Guest
    A thermistor or a thermal fuse are likely to be cheaper than a
    temperature-sensing IC.
    Tim
  5. plus the circuitry to make some use of it....
    Mike really needs to write a longer description f the problem and the
    function of the solution he wants.
    my finger can sense temperature, but it wouldn't be much use without a
    brain to act on the fact.
    David
