I don't understand. If you look at the first couple of lines of the
NDS9410a model, there's an extra pin. Pin 50 VTEMP. When I make a
symbol I have to include this pin. The model works but I need to
drive this pin with a 27Volt source. I'd rather have this pin be
driven by the normal .TEMP parameter. Is there a way to attach a pin
to a parameter?
Paul C
Aha! Someone has hokeyed up a model so that an applied voltage is
local temperature.
Are you wanting to do a temperature sweep, or some other analysis, but
set temperature?
If you do a behavior VCVS with expression = {TEMP}, you'll get a
voltage equal to the temperature.
(I'm pretty sure that works in v8.)
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice
480)460-2350 | |
| E-mail Address at Website Fax
480)460-2142 | Brass Rat |
http://www.analog-innovations.com | 1962 |
Anyone can be rude, but it takes a Democrat to be a real dirtbag.
