M
[email protected]
Hi guys,
I'd like to build a closed hot-box for an aerobic microbiology
experiment. The heater will basically be a 60W light bulb (or a string
of 5W Christmas tree lights), and I'm looking to run experiments at
around 90 degrees F.
The controller: at first I'd thought of using a microcontroller of
some sort, then I thought maybe I can use an off-the-shelf thermostat.
I went to homedepot.com, looked for the cheapest digital thermostat
they have, and found item 100047225. (If Home Depot allowed direct
links to their products, I'd post it; otherwise, you have to put the
item number into the Search box on the upper-right. Sorry about that.)
Now I'm wondering how I interface this thermostat with my 60W, 110VAC
lamp.
Specifications: Works With standard heating and cooling (millivolt to
24 Volt), 2 wire boiler
So, how do I use it? I'm guessing a simple relay from the thermostat's
outputs won't work (or would kill the battery inside the thermostat).
Any suggestions?
Thanks in advance,
Michael Darrett
lamp.
Any suggestions?
Thanks in advance,
Michael Darrett
