Integrator741
- Jun 16, 2013
- 125
- Joined
- Jun 16, 2013
- Messages
- 125
Good Evening,
I am going through some physic questions, hoping that will improve my chances of succeeding in exam, and I found a few questions about temperature and thermometers that I am not too sure.
1. When a particular temperature is measured on scales based on different properties it has a different numerical value on each scale except at certain points, explain why this is so and state at what points the values agree.
2. The resistance of a wire at temperature x degrees of C measure on a standard scale is given by R(resistance at unknown temperature) = R0(1+A(temperature)+10^-3 * A(temperature)^2), where A is a constant. When the thermometer is at a temperature of 50 C on the standard scale, what will be the temperature indicated on the resistance scale?
I had similar questions before, but I was able to solve them using a simple book called "Explaining Physics GCSE Edition". I know that they are not hard, but I can't understand them.
Thank you.
Thank you.
