R
Ryan Ashline
I have a video projector mounted in a sealed box which has an intake
with a fan pushing air in and an exhaust which has a second fan
blowing air out. The system keeps the projector supplied with enough
air to keep it cool but even with the fans mounted in the attack 10
feet away I can still hear them. What I would like to find or build
is something that will turn on the exhuast fan when tempatures reach a
certain level inside the box. When or if the tempature reaches a
second elevated level I would then like to kick on the intake fan to
increse the overall CFM the projector box is given. Currently I have
a wall switch that turns on a 3 amp dc power supply that feeds both
fans at the same time. One thought i had was to use two inexpensive
home hvac thermostates mounted inside the projector box to trigger
each fan seperatly based on the tempature set on each one. However i
am not sure if these are ac or dc and what i would need to get them to
control the fans. Another question I had was if switching the fans on
and off with lower the life of the fans?
Thanks for any help or direction anyone can give!
Ryan
Ryan
