temp switch
Discussion in 'General Electronics Discussion' started by Flat Tire, May 7, 2011.
  1. Flat Tire
    Flat Tire
    May 7, 2011
    I need a temp switch that will turn on a 110 plug for a pump when the sensor reads 135 degrees and turns off at 100 degrees. This might be a small question but a problem I need to solve. The temp sensor is coming off a Calefi hot water transfer tank. Calefi makes some controls but are expensive.
  2. davenn
    davenn Moderator
    13,654
    1,888
    hi there,
    Welcome to the forum
    try so googling on suppliers of temp controlled switching, there's sure to be a number of
    manufacturers out there :)
