Television Problem
Discussion in 'Electronic Repair' started by Chris, Apr 25, 2004.
  1. Chris
    Chris Guest
    I have a 9" Zenith television that has recently started to behave in an
    unusual manner. Over approximately a one second time interval, both the
    sound and the picture oscillate between being normal and having an extensive
    amount of interference. The set is about 15 years old and probably not
    worth having fixed. However, I'd be interested in fixing it myself if I can
    determine the defective component. It must be either introducing or not
    filtering a 60 hz signal. Any ideas?
    Chris
    p.s. The set is connected to a cable. I've tried various cable connection
    points in our house, with no change in the symptoms. None of our other sets
    are doing this.
