telephone ringer timer
Discussion in 'Electronic Basics' started by palito, Dec 22, 2003.
  1. palito
    palito Guest
    I know nothing about electronics and am looking for some help here.
    I need a telephone to ring for 15-20 seconds every 2-3 minutes for ten
    hours a day for an art installation. The ten hours a day part will be
    handled manually.
    I plan on using a Link-it (http://www.jechtech.com/linkit.pdf)
    but need to use a relay/timer to trigger off-hook condition for ringing
    time.
    With a 600 OHM resistor and a relay/timer plugged into source jack,
    Link-It manufacturer says I should be in business.
    The 4690A -8 -3 -2(http://www.artisancontrols.com/pdf/4690.pdf) seems
    like it might do it. I'm guesing.
    Any body think that might work? Better way to do it?
    Thx,
    Pat
  2. CFoley1064
    CFoley1064 Guest
    It looks good. Actually, you've approached your problem intelligently --
    separated the project into functional blocks, then tackled the challenge of
    finding vendors to supply parts which will handle each block.
    I haven't dealt with jechtech or the Linkit, but the .pdf file looks good, and
    their circuit looks like it will work as advertised. Artisan is a good,
    reliable manufacturer of TDRs and other control circuits, and aren't the most
    expensive outfit on the block, either. The 4690A -8 -3 -2 is the model you
    want if you need to use 115VAC line voltage.
    Good luck.
    Chris
