N
Number 6
I managed to get the dialling done acoustically by writing a sine-wave
synthesis program on the PC which responds to buttons pushed like a real
phone.
What I did wrong was that I did not raise the second tone (of the dual
tones used for dialling) by 3dB as somebody suggested.This compensates for
the role-off of the line freq response.It refuses to work without this. The
duration is far less critical.
Thanks for that - now I can dial just by holding the phone next to the PC
loudspeaker - works perfect!
However, I wish to dial directly into the line. I have a telephone 1:1
isolation transformer for this with zeners to block the ringing voltage and
a series capacitor to block dc - I can hear somebody on the line fine but I
cannot seem to 'send' a signal down the line at all.At least the signal is
very weak indeed.
So to take things step at a time - how do I get my dial tones to feed
directly into the phone-line? I tried feeding from the PC speaker via the
transformer but it won't cut the ice.
I also tried this the easy way via a modem by sending ASCII commands. This
works too but again I have no way of sending a signal down the line once the
phone connects - I can dial and it connects at the other end. I can also put
the phone on and off the hook.What am I doing wrong? Surely the signal
strength is not that high - or is it?
Tom
phone.
very weak indeed.
Tom
