For Sale: Tektronix DG2020A Digital Data Generator
Status
Not open for further replies.
donh
Jun 3, 2013
Jun 3, 2013
Tektronix Data Generator.
Has options 02 and 1R
This Data Generator has very low hours, is in very good condition and perfect working condition.
It is a 36 channel with the Rack Mount option as well.
These are currently selling for over $12,000.00.
Features and specifications of the Tektronix DG2020 Pattern Generator include:
• 200 Mbits/s maximum output data rate - Up to 64 K words/channel data word length
• Up to 36 output channels in 12-channel incrememnts
• Up to 36 independent variable delay output (20 ns, 100 ps minimum resolution)
• Output level
• Flexible sequence control and data jump
• Try-state control
• Powerful and easy-to-use data built-in editor
• Data import from various instrument and other source
Output Data:
• Data Rate: -0.1 bps to 200 Mb/s
• Sampling rate: 0.1 Hz to 200 MHz
• Resolution: 4 digits
• Period jitter: <50 ps RMS (at 200 MHz)
• Accuracy: PLL On, ±50 ppm; PLL Off, ±3%
• Data Depth: -64 K to 64 K word (1 increment)
• Data Width -12 bits (std), 24 or 36 bits (optional)
Sequencer
• Max number of lines: 4096
• Max data repeats per line: 65536 or infinite
• Max number of jumps per sequence: 4096
AUXILIARY INPUT
Clock - SMB connector (rear)
• Threshold level: VIH>0.7 V, VIL<0.3 V
• Maximum input voltage: ±2 V
• Frequency: DC to 200 MHz .
• Impedance: 50 Ω, terminated to +0.5 V
Trigger - BNC connector (front)
• Level: -5.0 V to +5.0 V
• Resolution: 0.1 V
• Impedance: 1 KΩ or 50Ω
• Hold off: 500 ns minimum
AUXILIARY OUTPUT
SYNC Output - BNC connector (front)
• Level: Positive TTL pulse. 50 Ω
• Output Term: 6 Clocks
EVENT Output - BNC connector (front)
• Output Term: 8 Clocks
CLOCK Output - SMB connector (rear)
• Level: 1 V (Typical) into 50 Ω
IN EXCELLENT WORKING CONDITION
Asking Price $5,000 /If you have any questions, please feel free to contact me. Thank you....
Status
