JM
I recently bought a CSA802A - a nice clean unit with low up time. Unfortunately it developed a fault in transit, and the extended diagnostics are showing the following faults :-
Timebase - Block M/F I/F - Comm T3112
Timebase - Block M/F I/F - Strobe Gate T3311
I pretty much stripped the whole unit down (I wanted to backup all the EPROMs anyway) and have checked all the supplies and all inter board cabling. All socketed IC's have been checked for correct seating. From a visual inspection there is nothing obvious. The unit was very well packaged, with nodamage to the packaging on receipt, and I'm confident that it was working when sent.
I thought I'd just post in the off chance that someone is familiar with theunit and can advise on the probable problem. Given that there isn't schematics available for these they are a pain to trouble shoot. I suppose it'll be cheaper in the long run to find a donor unit and swap boards until thefaulty board is identified, rather than reverse engineering the unit.
John
John
