C
ChairmanOfTheBored
Yes it very well may. Since freeze spray would take the parts it hitsThat's the point. The problem already makes the scope unusable, some freeze
spray won't break it any worse.
below the dew point in nearly any place around, it will condensate water
immediately. One thing that LCD interfaces do NOT tolerate is moisture
between the contacts, and we already mentioned that it is NOT going to be
a component in a failure mode. So where exactly do you think this freeze
spray should be pointed such that it is going to fix a problem, or show
where one is at?
It won't, put simply. NORMAL finger pressure placed onto the contactors
at the LCD interface connections will do far more toward those goals than
introducing a moisture laden failure prone procedure ever will.
Freeze spray is for zapping a suspected transistor or FET with, not a
connectivity based mechanical contact issue. There is a place and time
for every fix in electronics, and freeze sprays and low voltage LCD panel
edge connections are NEVER one of them.
