Tek 465 scope
Discussion in 'Electronic Equipment' started by PKREZY7, Apr 3, 2004.
  1. PKREZY7
    PKREZY7 Guest
    Hello,
    I would like to get information/data sheets on the Tek 465 scope. Is there
    a .pdf file I can download?
    Thank you.
    Pete
  2. TekMan
    TekMan Guest
    Data is online, e.g, all 2nd hand online retailers.
    www.singer-elektronk.de in Gemrnay, various seller in usa, for
    instance.
    Or check ebay.com: Most sellers include the dat & picture in their
    auctions ;-)
    hth,
    Andreas
  3. Jamie
    Jamie Guest
    its an 100 Mhz dual trace.
    uses older phos memory screen (not very usefull if you ask me)
  4. JW
    JW Guest
    *shrug*
    A tool is only as good as it's user makes it. I've been using mine for
    close to twenty years, troubleshooting everything from monitors, power
    supplies and floppy drives and from to Multibus boards to Pentium-class
    microprocessor based embedded systems. I've only recently upgraded to a
    2445B when the traces in the 465 developed 60Hz noise - and yes I know
    it's probably the power supply caps, but I can't be bothered to repair
    it.
  5. Jim Adney
    Jim Adney Guest
    The 465 was NOT a storage scope, although there were versions, 464 &
    466, which were.
    Of course any CRT has some phosphor persistence, but this is generally
    not confused with memory. Tek made a number of CRT storage scopes
    which used "screen storage" which used a special CRT which would keep
    the phosphor refreshed and hold an image on the screen. The 465 was
    not one of them.
    Digital storage is different from both of these.
    The 465 and 465B were probably 2 of Teks most popular scopes. Both are
    excellent.
  6. Jamie
    Jamie Guest
    i was referring to the memory screen device.
  7. Jamie
    Jamie Guest
    my 465 does have a Phosphor Memory CRT.
    it just that they get a little sucky afrer a while
    they don't show a nice even image after a while.
    and it does hold it the image for quite some time.
  8. Jim Yanik
    Jim Yanik Guest
  9. Jim Adney
    Jim Adney Guest
    Any chance that you mean 564? The 465 doesn't take plugins; the 564
    does, and has screen storage.
  10. Jamie
    Jamie Guest
    P.S.
    sorry about that, i have a 464 not a 465./
  11. Jamie
    Jamie Guest
    thats my misstake, i have a 464 not a 465.
    and that does have CRT Phos storage.
  12. Jim Adney
    Jim Adney Guest
    Yes, the 464 is a storage scope, as is the 466. One of them was screen
    storage and one was digital storage, I think. I don't know which was
    which.
    From your comments, I gather that the 464 was screen storage.
  13. Jim Yanik
    Jim Yanik Guest
    Both 464 and 466 are 'screen storage',the 468 was the digital storage
    scope.
    And there also was the much earlier 465 with a very low-performance digital
    storage option(modified product?),that looked like a DM44 piggyback module.
  14. Jim Adney
    Jim Adney Guest
    Okay, but what's the difference between the 464 and the 466?
    I don't think that option shows up in any catalog. I've certainly
    never come across any mention of it before, except possibly from you.
    I've always been surprised at the various non-stock options that Tek
    could come up with, however.
  15. Jim Yanik
    Jim Yanik Guest
    466 has reduced scan,giving a higher storage writing rate.
  16. ddwyer
    ddwyer Guest
    465 etc have much greater dynamic on screen range than any? digital
    scope approx to uV in 10V.
    Can see rf at low level on audio which would otherwise require spectrum
    analyser.
