Tek 2465A diff amp nonlinearity
Discussion in 'Electronic Equipment' started by Walter Harley, Aug 4, 2005.
  1. When I feed a 1V sine wave into both ch1 and ch2 of my Tek 2465A, and set it
    to display the difference (invert ch2 and add the channels), I do not see
    the expected flat line. Rather, there are some bumps.
    So, I presume this means that one or both input amps are not quite linear.
    My questions are:
    1. How much nonlinearity should I expect, in a working and well-tuned 2465A?
    2. Anybody got any pointers to where in the service manual I should look,
    for diagnostics and troubleshooting of this? (The service manual I have is
    a not-so-good photocopy so it's very hard to search through without at least
    a head start, and I haven't spent much time with it.)
    3. If I wanted to buy a used differential instrumentation amplifier, ideally
    with bandwidth >= 100MHz, ground-referred common mode range >= +/-15V,
    input-referred wideband noise <= 250uV and differential gain >= 20, is there
    a "classic" model that I should search for? (Sort of like the 2465 'scopes
    are a "classic" - something that would be easy to find used, easy to find a
    manual for, and that would be pretty reliable.)
    Thanks!
    -walter
  2. Have you tried to play with the var.gain at both channels to match
    the gain of them exactly?
    At what frquency did you do this? (Phase match maybe...)
    And at what V/Div of the Channels did you do this measurement?
    Did you raise the input sensivity to see that behaviour and maybe
    overdriven the input amplifiers? (The "cancelation" of the signals by
    "inverted adding" is done after a few amplifier stages which can of
    course saturate than and can do this in different matter (overdriven
    Amplifiers are not specified exept the recovery time)
    Just a few ideas.
    Jorgen
    dj0ud
  3. Yes - sorry, maybe I should have been more detailed. The residual is not a
    sine wave, so it is not just a phase or amplitude discrepancy. It looks as
    if the two channels track well over most of the input range but have
    differences at several small, distinct ranges. So the residual is a flat
    line with a couple of triangular spikes at irregular locations
    Something low, like 1kHz.
    I think I did that initially and then realized it and backed off and still
    saw the problem. But let me re-check and make sure that wasn't what was
    happening.
    -walter
  4. Jim Yanik
    Jim Yanik Guest
    The manual should have the common mode rejection ratio specs.
    The input of the 2445/65 series is not intended to be equal to a true
    differential amp.
    TEK still makes differential amps for their scopes,probably listed under
    accessories.
  5. Well, I must have been doing something funky, because now it's not doing it
    at all - it's behaving just fine. The only distortion is from clipping, and
    even that only when I crank the gain way up.
    Thanks anyway...
  6. I see a lot of diffamp plugins, but the only standalone diff amp I see
    popping up on eBay is the P6046 differential probe.
    Looking at the pictures, I don't quite understand how that probe is supposed
    to work - it looks sort of like the spacing between the two input pins is
    fixed?? I was envisioning something that would have inputs for two separate
    probes, rather than something that had a single probe with two pins. I want
    to be able to do things like comparing signals at various points on the left
    and right channel of a stereo amp.
    -walter
  7. Jim Yanik
    Jim Yanik Guest
    look at TEK's website;www.tek.com.
    I do not see what use a differential probe would be for that use? What
    useful info do you expect to get from it? No stereo amp will be matched any
    better than the ordinary non-differential scope inputs inverted and added.
    And you would have to feed the -same- signal to both channels.
    BTW,some other company(not TEK) used to make a power supply/"mainframe" to
    allow one to use a 7A22 or 7A13 differential plug-in as a standalone
    instrument,with a single-ended 50ohm output BNC to feed a regular scope
    input.I can't recall the specific company,though.
  8. tekamn
    tekamn Guest
    Walter,
    as Jim mentioned: The P6046 probe alone won'T help much. This probe is
    designedto work with a diff amp unit like the 7A13 or the 7A22 or
    similar. The 2465A scope definetely has no such input. So if you really
    need to do differential masurements: A 7A13 with a 7313/7603/7613
    mainframe will get you more out for the solution.With the siganl
    through output of the 7xxx-scope you can still connect to your 2465A -
    but I guess that's only necessary if you wantthe cursor meas to do ;-)
    hth,
    Andreas
  9. Jim Yanik
    Jim Yanik Guest
    No,it's not.
    It can work with any single-ended scope input.
