Tek 2430 scope
Discussion in 'Electronic Repair' started by Tracy Fort, Nov 11, 2003.
  1. Tracy Fort
    Tracy Fort Guest
    I've aquired a Tek 2430 scope that has some issues. I was wondering if
    there were problems that were inherent to this model? At times, the
    scope powers up and goes through diag just fine and will work for
    hours. Then there are other times that the scope will do nothing. It
    powers up but you get no relay clicks and never get a screen image.
    Then there are other times that the trace freezes on the screen and
    the scope acts locked up. You can power the scope off and then back
    but you will get the no screen issue that I mentioned above. I'm
    thinking cold solder joint or component heating issue.
    Any ideas?
    Tracy
  2. Jim Yanik
    Jim Yanik Guest
    Perhaps power supply problems? Some PS electrolytics may be marginal in
    ESR.(aging)
    Sounds like a job for a Dick Smith ESR meter (music blaring...) :cool:
  3. Have you checked the battery?
