Technics SA5160
Discussion in 'Electronic Repair' started by Engineer, Jun 24, 2004.
  1. Engineer
    Engineer Guest
    Per my earlier post, I have a distorted LH channel (RH is fine.) The
    LH ch. is clipping on one 1/2 cycle almost completely, other 1/2 cycle
    OK, seen on 'scope at the PA drive, too.
    Can anyone point me to the schematic of the whole SA5160 unit or even
    just the power amplifier S/C block, an STK0177? This is looking like
    a lost cause so far...
    Thanks for all replies,
    Cheers,
    Roger
  2. The associated output IC is most likely defective. Some of its support
    components including the drivers for it are most likely also
    defective.
    As for the service manual, it should still be available from
    Matsuchita. The cost is approximately $40 to $60 US.
    Service people will not give out copies of service manuals, because
    they had to pay full price for them, and that the manuals are
    copyright material. If a service center is sited for illegal
    distribution of manuals, they can loose their any service agreements
    that they have, or even be prosecuted for copyright infringements.
    Jerry G.
  3. Engineer
    Engineer Guest
    Thanks, Jerry. Sounds like the Kiss of Death to me.... The whole
    unit when working is only worth about US$25 (it's not a "good"
    Technics) so there's no point in buying manuals and a replacement
    power amp IC, etc. and putting in the time. Also, this unit is
    constructed to be almost unserviceable - can't even get to the back of
    the PCB without taking it out. Pity because the AM/FM tuner part is
    working fine (but I have a surplus of tuners!) - it's to the cannibals
    for this one!
    Cheers,
    Roger
  4. Eugen T
    Eugen T Guest
    All Technics, even newer ones are built that way. You have to completely
    take the whole receiver/amp apart to get to the bottom of pcb :(
  5. Engineer
    Engineer Guest
    Not the SA-200. The bottom comes off (got one!)
    Cheers,
    Roger
    (snip)
