Tech Support? - Help!
Discussion in 'Electronic Design' started by minski_wit, Mar 31, 2006.
  1. minski_wit
    minski_wit Guest
    Hello,
    I am working on a project where i'm looking to deliver power from a
    12vdc, approx 10A, battery to a mechnical relay which will switch when
    i send a signal from my microcontroller.
    The catch is that, as most linear actuators need positive and negative
    voltage, so do mine..
    I am thinking i may be able to accomplish this if i use two mechanical
    relays but thats just a guess. I was thinking some kind of setup with
    an inverse amplifier but that certainly does not not manage such
    current.
    If anyone has any suggestions I would greatly appreciate it
    Thank You
  2. Tim Wescott
    Tim Wescott Guest
    Do a web search on 'H-bridge'. 12V at 10A is pretty tame these days.
    If you are bound and determined to do this with relays you could use a
    SPDT relay to turn things on and off, and a DPDT relay to reverse direction.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
  3. If you have a spare change over set of contacts on the relay, you can
    use this to switch the -12V. No electronics involved
    martin
