TEAR DOWN - Diode really needed for solar charger?
Discussion in 'General Electronics Discussion' started by NuLED, Jun 13, 2013.
  1. NuLED
    NuLED
    294
    Jan 7, 2012
    I had a AA charger that was getting rusty inside, so I decided to try and salvage the solar panel itself (I did).
    But anyway, before I cut the wires, etc. I noticed that the circuit has a diode.
    Is it really necessary?
    I checked the polarity of the panel (using DMM) and the + goes to the + of the parallel AA battery case, and the - of the solar panel goes to the - of the battery connectors.
    Does polarity on solar panels change? Or is it to block the batteries themselves from discharging against the solar panel when the voltage drops from sunlight?
    PS - how do we tell the basic specs of the diode? It says 3, and then 817 on the diode. Web pages I searched seemed to refer to a color scheme like resistors but that's not what I see on this diode.
  2. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    I have no hands on with solar yet, but my research into is getting extensive.
    the diode seems to be so when the battery is charged it does not discharge onto the panels.
    the diode specs I leave to others on the forum but I hope I have helped in some way
  3. john monks
    john monks
    693
    Mar 9, 2012
    Solar cells voltage polarity is in the forward bias condition when placed in the sun. So as donkey says the battery will discharge without the diode.
  4. NuLED
    NuLED
    294
    Jan 7, 2012
    ok thanks guys
