K
Kevin Walton
I'm doing some work with a GPS, see here for the full story:
sci.electronics.design subject: Cheap 433 Mhz Serial TX & RX - Which
ones!
It is a USB GPS but I need a serial output.
I have opened it up and it just uses a PL-2303 USB to Serial
converter:
http://tech.prolific.com.tw/visitor/fcabdl.asp?fid=17151518
with the SIRF 2e/LP GPS.
So I have tapped off of pin 5 (rx) and 7 (gnd) leaving the original
chip pins connected and connected to a PC serial port.
I can still operate the gps from the USB, it just uses a software
driver and pretends to be com6, connecting at 4800 8n1 I get my data
stream.
However, connecting to the serial tap at 4800 8n1 gets me data,
streamed at the right sort of rate and intervals - but it's
gobldegook. I have tried all combinations of 8/7, n/o/e and 1/2 at
4800 but no luck, just different gobledegook, this is the sort of
thing:
•šæææfÍææææÍšææææfÍææææMššš3¦¦æ&æÍš5gey=·â¾ââúN:">*>*F">>N>>>>F>>>>NÆN>>>>>F>>>>NêN>N>>N*>F>N>F>NÊN>F>NÊN>F>N>>>>V""ÊÖnâ¾â²úNúN:NNNNNNNNNNNNN*>F>N*>F>N*>F>V>*ÊÖn⾶ÊòN:">*>
Any pointers on how to fix the issue? Is there software that can tell
me what rate and format the data is coming in at? What should a scope
show me on the serial line? Am I using the right ground, I shouldn't
use the VDD_232 pin should I?
All ideas greatfuly received.
Kev
ones!
converter:
stream.
thing:
Kev
