Tape deck power issue
Amkdl
Mar 24, 2021
4
Mar 24, 2021
4
I have no real electronics experience, but recently changed the belts on an Aiwa 450F tape deck. It seemed relatively straight forward, but now there is no power when i turn on.
What could i have done and how do i fix it please?
Harald Kapp
13,700
13,700
Check any cables and connectors for correct fit.
Harald Kapp
13,700
13,700
You checked the fuses?
Do you have a meter to measure voltages?
Martaine2005
May 12, 2015
4,932
May 12, 2015
4,932
I would suggest taking it a part again to re-trace your steps.
Check connectors orientation and that they are seated correctly.
This is obviously no coincidence.
Martin
Amkdl
Mar 24, 2021
4
Mar 24, 2021
4
Hi I dont have a meter to check sorry. I have also taken the main internal cassette player section out which holds the belts and replaced, plus checked all connectors orientation - all seems fine. Could I have damaged the mother board somehow? Maybe frazzled it somehow?
Martaine2005
May 12, 2015
4,932
May 12, 2015
4,932
Highly unlikely the board got damaged.
Possibly a wire or connection broke while taking it apart.
Unfortunately, you will need a multimeter or some kind of continuity tester to check.
Martin
Amkdl
Mar 24, 2021
4
Mar 24, 2021
4
Thanks Martin. Using a tester is outside my skillset! Guess my only option is to sell on ebay as spares!
Martaine2005
May 12, 2015
4,932
May 12, 2015
4,932
Well, you can sell it with ‘new’ belts fitted. :)
Shame really.
Martin
