Jeremy D. Grotte
I'm building a small controller for a project. I've also got a supply of
cases that fit this project very well. It's about the size of a keyfob type
thing, one small 5way tact switch and an RGB LED. Problem is the case is
too thick. The board fits nicely side to side, but sits too far in the case
to be able to move the tact switch around.
I've tried using some foam to take up the extra space, and it keep the board
in there nice and snug and it works great.
But I've also forgot to mention that the controller also has 3 MOSFETs on
the back of the board each dissipating about 1 watt (worst case). The
MOSFETs end up melting a spot in the foam. The MOSFETs get hot, not
terribly hot, but I wouldn't want to hold one in my hand for more than a few
seconds (i.e. spit doesn't sizzle on them!).
Any swell ideas on what I could use to take up the extra space?
I saw the thread on potting cases, but I don't think that's 100% appropriate
for me. I thought about globbing some hot glue on the top of the board and
holding it to the top of the case instead of spacing it up from the bottom.
No good there either as the glue would eventually seperate and leave me with
a push button flopping around.
TIA...
JDG
TIA...
JDG
