TA7200 = TA7238 ?
P
Phil Allison
Hi all,
can anyone find or supply pin out data for the TA7238P audio amp IC ?
Is it the same as for the TA7200P ?
Any other pin compatible sub for the TA7200P ?
......... Phil
S
Steve Mills
Hi all,
........ Phil
Attached is the data I have on the TA7238P,
not sure about the TA7200P
regards
Steve Mills
P
Phil Allison
"Steve Mills"
"Phil Allison"
** Sorry Steve,
your attachment is not visible on either of my two newsreaders.
Can you please just list the pins and their function for the TA 7238 ???
............... Phil
R
red rooster
"Steve Mills"
"Phil Allison"
** Sorry Steve,
.............. Phil
Sorry about the format (It's a pdf Adobe Acrobat doc) Anyway here's
the info:
TA7238P 9w Amplifier
PIN 1 Vcc (typ. 24v) (max 32v)
PIN 2 Filter capacitor (typ. 4.7uF/63v) (pin 2 -> ground)
PIN 3 Mute
PIN 4 Input (+ve)
PIN 5 Feedback filter capacitor (typ. 22uF) (pin 5 -> ground)
PIN 6 Input (-ve)
PIN 7 ground
PIN 8 ground
PIN 9 Output (to speaker, capacitor coupled)
PIN 10 Feedback cap (typ. 47uF) (pin 9 -> pin 10)
P
Phil Allison
"red rooster"
the info:
PIN 3 Mute
PIN 4 Input (+ve)
PIN 6 Input (-ve)
PIN 7 ground
PIN 8 ground
** Thanks very much.
The two devices have totally different pin outs.
.............. Phil
Similar threads
Replies
Views
3K
Franc Zabkar
F
