T6963C simple Question
Discussion in 'Electronic Basics' started by dAN, Oct 28, 2005.
  1. dAN
    dAN Guest
    I'm writing a library for an easy use of my 240x128 LCD display with
    the T6963C controller.
    I can display pixels and character where I want. No problems with that.
    I would like to develop with 8 bits display in graphic mode and 6*8
    display in text area.
    Can I do that?
    The only way to change the font is by modifying the state of the FS Pin
    by hardware. But when I modify the font, it also modify the graphic
    area (for example, if I display 11001111 in the left upper corner it
    will be shrinked to 001111)
    Merci,
    DL.
  2. dAN
    dAN Guest
    well..
  3. I don't think I fully understand what you mean. If you are asking if it
    is possible to have text and graphics on the screen simultaneously, then
    the answer is yes. I played with one of these a few years back so I
    don't remember the details now, but I do believe that text and graphics
    together is possible as long as there is enough RAM.
    After reading this a few more times, I think I understand now. You are
    saying that the FS pin affects the appearance of the graphics that are
    displayed when you toggle it. I think I remember something like this
    happening to me as well, but that was so long ago I don't recall for
    sure. It should be documented in the datasheets, did you read them
    thoroughly?
  4. Well?
