System III
Discussion in 'Security Alarms' started by A.J., Jul 6, 2007.
  1. A.J.
    A.J. Guest
    Anybody here with hands on experience with System III ? Need some tips with
    fine tuning our new toy.
    Thank you !!!!!
  2. have had a bit of experience setting up the System III with the DRLIP
    and the digital cards. What appears to be your issues?
  3. A.J.
    A.J. Guest
    Noticed a 10 seconds delay between end of dialing and hearing a handshake
    tone from the receiver, is the delay caused by the AHS lookup ? What is the
    best way to switch the primary server to bakup ? Do you have more than 1 IP
    card in the same receiver, and are they connected direct to the net or
    behind routers ? etc. etc.
    Thanks !!
  4. I only have one receiver (no backup). Not sure about the 10 second
    handshake...will see if mine is the same (don't believe it is). I do
    not use the AHS lookup. Will look into it. As for the IP cards I have
    3 IP cards in the receiver. All three are behind different routers (one
    on a VLAN, one on a VPN over a WAN, and the third on a VPN onto the
    internet). The three are because each IP card needs to talk to a
    different type of network.
  5. A.J.
    A.J. Guest
    I really appreciate if you can confirm the 10 seconds delay for me. As for
    the AHS lookup, that 's one of the beauties of using the System 3, is there
    a reason why you are not using the feature ?
    Regards,
