S
Spur
Hi all,
We have an FPGA that works on some crystal clock. This FPGA should
interface with a processor - the processor reads and write data
to the FPGA's registers. The processor bus has a clock of its own,
to which all the bus signals are synchronized. The frequencies of
the clocks are the same, but there is an unknown phase, of course.
The problem is to reliably get data from the CPU, while still working
on our own clock.
The favorite solution so far is double-sample the CPU signals, just
connect them to two registers, one after another, both on our clock,
this way the output of the 2nd register is stable (no meta-stability).
Note: the CPU generates no signals that last less than 2 full clock
cycles, thus allowing us to do this.
What do you think ?
Thanks in advance
on our own clock.
What do you think ?
Thanks in advance
