sxc 1901F from a micronta multimeter 22-193
Discussion in 'Electronic Components' started by alpibucky, Apr 20, 2011.
  1. alpibucky
    alpibucky Guest
    Hello,
    Does anybody have a datasheet of this IC.
    My 22-193 readings are wrong and the BATT indicator appears
    continuously, but the batteries are good.
    With my kind regards,
    Alpibucky
  2. ehsjr
    ehsjr Guest
    Could it be a dual comparator, NJM2903D ?
    The RS parts list seems to indicate that as a possibility.
    If the chip is a comparator, the circuit is likely dividing
    the battery voltage, and comparing the result to a reference.
    That said, examine the battery connections, and circuit path
    from the battery to the PCB's. More likely the problem
    is in the path somewhere, than a defective IC.
    Ed
  3. Franc Zabkar
    Franc Zabkar Guest
    AFAICT, the SXC1901F was manufactured by Seiko Instruments.
    FWIW, the following document lists a service manual, cat# 10824373, NP
    Part # MS2200193.
    Parts List for 220-0193 AUTORANGING FOLDING DVM:
    http://support.radioshack.com/support_meters/doc21/21609.htm
    - Franc Zabkar
  4. Shaun
    Shaun Guest
    once those Radio Shack multimeters go astray, that is usually it for it. Go
    buy a fluke.
    Shaun
    "alpibucky" wrote in message
    Hello,
    Alpibucky
