Swithching regulator (Buck Converter) with LTSpice question
Discussion in 'Power Electronics' started by RobinLeblond, Oct 20, 2018.
  1. RobinLeblond
    RobinLeblond
    Oct 20, 2018
    Hello, I'm in the process of learning switching regulator and I'm using LTSpice as a simulator and teaching help. I found a video on YouTube explaining the SR, and I did exactly what it was demoed and didn't get the same results.
    Simply said, I getting the same result but with a 300mV at the output instead of 5.6V, why ?
    Here is the link of the video :
    In attachment, you will find my LTSpice schema and a few screenshots.
    Thanks a lot!
  2. Harald Kapp
    10,060
    2,146
    That is rather logical as you've set D=0.05 whereas in the video it is D=0.5.
    1/10 duty cycle -> 1/10 output voltage (roughly).
    Cheers,
    Harald
