G
Glenn Ashmore
I have four 3.6V 800mAh LI-Po prismatic cells that I want to build into a
pack for a radio control receiver/servos and video unit. It is carried
aloft by a kite so weight and space are the governing variables. Power
density is important. The receiver and servos require 5V and will draw an
average of 150 ma. The video Xmitter requires 5V at 250 ma for a total of
about 400 ma. I have found a couple of micro switching voltage regulators
that claim 85% efficiency converting 14.4V to 5V..
I am thinking I could assemble the cells into a 14.4V 800 mAh pack and feed
the devices through the regulator. My question is what is the effective AH?
Here is the way I figure it:
14.4 V * 800 mAh = 11.52 watt hours
11.52 Wh * 85% efficiency = ~9.8 Wh
9.8 Wh / 5V = ~1,960 mAh
1,960 mAh / 400 ma = ~ 4.9 running hours (say 4 hours)
Is my logic correct? Does a switcher convert the excess voltage into
additional amp hours?
Glenn Ashmore
I'm building a 45' cutter in strip/composite. Watch my progress (or lack
there of) at: http://www.rutuonline.com
Shameless Commercial Division: http://www.spade-anchor-us.com
Glenn Ashmore
