switching the VSS line of an IC
Rajinder
Jan 30, 2016
568
Jan 30, 2016
568
Dear all,
I have a IC which I need to switch off when not in use as it draws a current of 100uA in standby. I think the best way of doing this would be to disconnect the 0V line via a switch i.e. transistor or FET. I have one pin of my PIC I/O line which I could do this with.
I am looking at a NPN to control the FET (which will be in series with the 0V line). The FET needs to have a low RDS on.
Can anyone help with the circuit or advise? I have a problem understanding the maths behind doing this too.
Thanks in advance,
Raj
Harald Kapp
13,700
13,700
You better switch the positive supply to ensure a good Vss connection at all times. When you switch Vss, there will be a considerable resistance in series with Vss in the on state which is detrimental for most IC's operation.
You also need to be careful about input and output connections to the IC. ICs have input protection diodes to Vss and to Vcc. When you turn off the supply voltage, these diodes can become conductive and supply the IC with power throughthe internal Vcc and Vss connections. As this is not a normal mode of operation, the IC can in the worst case consume even more power than in idle mode.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
Try looking for an IC that will switch into ultra low power mode. They generally have a pin just for that purpose. Never used one.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
