The Toroidal powers the audio amps, that are under the heatsinks.
Thats all that does.
The rest of the pcb is powered by the PSU.
If you look closer - you can see the `dark lines` that are the underside of the PCB, power lines.
You can see on the top photo, where these connect to the PSU connection.
A description of the layout...
Top left:
Power input, turned on by a solid-state relay - thats controlled from the parallel port on the Commodore Amiga 3000 computer thats the `heart` of the VR machine. (Thats another story - I have a few non-working Amigas!)
The ribbon cable that is connected to the edge, is only for LED`s to show power is on - one for each +/-5, +/-15 from the PSU, and +/-25 thats from the toroidal for the amps. The LED`s also show Amiga power and HDD activity. - 8 LEDs in total.
The long ribbon under the toroidal is for the VR tracking PCB serial connection - PCB not installed on this photo.
Orange connector in the middle - is a power connection for the tracker PCB.
2 x 15 pin D sockets - for L/R joystick input on the machine.
Bottom Left:
Video circuit.
Video is controlled, switched and `protected` with the MAX453/452 ics. The two 25pin dplugs are for the headset
The IDC connector is for the `control console` - flashing buttons for option selection.
And of course, the external audio amps.
Top Right.
The line of ICs, are simple logic, Shift register, Or gates, And gates, 555 timer - This is to `dispense` the 8-bit data from the Amiga` parallel port:
Console light on/off/flashing
Video switching (External display - GFX card or Amiga output)
AD7111 control - system volumes - CD, Amiga audio, MicNet (player to player communication network)
A group of Op Amps to control the audio.
And in the top right corner - the bass & treble tuning.
Bottom Right.
Other than the PSU - Joystick trimming circuit.
The 4 pots at the front (right on photo) are left/right headset screen brightness, and external / headset audio volume.
The connections on the back (left on photo) from top to bottom.
Power - 240/120V
Coin-Op - credit module.
Parallel port in from Amiga
Left Joystick to Amiga
Right Joystick to Amiga
Micnet connection in/out
CD audio in
Amiga audio in
Amiga Video connection
Right graphics card input
Left graphics card input.
As for testing.
Low ohm out - I assume you mean check ohm between 5v+ and Gnd? at various points?
When I try to power it up - it seems that I get 0v out of the 5v connection.
I cant check closer with a higher resolution to see if I get any better readings over the board.
I will double check it works or not, with another PSU though... to fully decide if the fault is the PSU for the PCB - as I cant honestly remember!
