Switching power supply question
Discussion in 'Electronic Design' started by [email protected], Feb 23, 2008.
  1. Guest
    A swithing supply is a feedback control system. Therefore why doesn't
    it oscillate when you put a capacitive load on it? It should bugger up
    the phase margin.
    Wab
  2. John Larkin
    John Larkin Guest
    Probably because some clever person designed the loop so that it
    becomes more stable as you add capacitive loads.
    John
  3. If the dominate pole for the control loop is made up by the
    impedance of the supply feeding the output capacitor, then
    adding more capacitance just shifts the 3db corner frequency
    down. Then there are hysteresis controls that just bounce
    the output voltage between two slightly different voltages.
    These are unstable, by design, but the oscillation
    amplitude is controlled. Adding capacitance just slows the
    oscillation cycle.
    But there are lots of other loop designs that are
    destabilized by adding enough pure capacitance across the
    output. Many need a little resistance in series with a
    significant part of the total capacitance to add a
    stabilizing zero to the total response.
  4. Joerg
    Joerg Guest
    Does that mean there can't be many clever persons in groups tasked with
    LDO design? SCNR ...
  5. legg
    legg Guest
    Actually, it will do so, unless you intend otherwise.
    This is one of the basic tenets of electronic design.
    RL
  6. John Larkin
    John Larkin Guest
    Apparently not. A couple of people make opamps that tolerate any
    capacitive load. The concept is pretty simple: the output pin is one
    end of the compensation cap; adding load capacitance doesn't add a
    pole to the loop, it just shifts the dominant pole down. The guys who
    do LDO's ought to be told about this.
    John
  7. Jim Thompson
    Jim Thompson Guest
    Not quite as simple as that. There's some feed-around techniques used
    to isolate the load.
    They can't, without an extra pin, and an external R/C... LDO's can't
    afford to waste power with implementing the R on-chip... a small R
    forces a large un-integrable capacitor.
    I recently did one on-chip, but the current ability was only 15mA,
    charging an external capacitor, which was then dumped with 2.2A.
    ...Jim Thompson
  8. John Larkin
    John Larkin Guest
    This is what I had in mind, per Fig 1.
    http://www.national.com/ds.cgi/LM/LM8261.pdf
    The load isn't isolated, it becomes part of the compensation. The
    transistors operate in "LDO" mode, namely with the output coming off
    the collectors, not the emitters.
    The 8261 is a very handy gadget to have around.
    John
  9. Jim Thompson
    Jim Thompson Guest
    It's a "simplified" schematic. Add up the poles if it were
    implemented purely as shown, and you'll see why a zero is required
    somewhere... for capacitive loads it needs to be associated with the
    output configuration.
    BTDT (almost daily :)
    ...Jim Thompson
  10. Marra
    Marra Guest
    It depends on the feedback function.
    You get the same with motor speed control.
    Thats why someone had to use PID to control a motor.
  11. Robert
    Robert Guest
    So LDO Designers aren't as stupid as might be assumed?
    Robert H.
  12. Tim Wescott
    Tim Wescott Guest
    Cruise control is a feedback control system, yet I think I could load up
    my wife's station wagon with boxes and boxes of capacitors and have the
    cruise control work fine.
    Just because many (but not all!) op-amp circuits go unstable when they're
    capacitively loaded doesn't mean that all electronic feedback circuits
    will go unstable when capacitively loaded.
    Tim Wescott
    Control systems and communications consulting
    http://www.wescottdesign.com
    Need to learn how to apply control theory in your embedded system?
    "Applied Control Theory for Embedded Systems" by Tim Wescott
    Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
  13. Joerg
    Joerg Guest
    But it's a Dollar a pop. Yikes.
  14. Joerg
    Joerg Guest
    That the point. We discrete designers do not mind at all to have to add
    a cap or even a more elaborate external loop. We are used to that from
    PWM controllers. It can't be too expensive to go from a SOT23 to a SOT23-5.
  15. MooseFET
    MooseFET Guest
    It depends on how stupid you assume they are. There are also some
    mistakes that it takes very smart people to make.
    In the past I have made some "do it your self" LDOs. It is very easy
    to make them stable with any load capacitance you you accept a crappy
    load regulation.
  16. MooseFET
    MooseFET Guest
    Let me be the first to say "use a PIC" in this thread. ADC->MICRO-
    chips have enough bits, people may not notice the chatter.
  17. Joerg
    Joerg Guest
    First post must have been picked up by a wind gust (it's ugly out here
    right now).
    We discrete designers would not mind an extra pin one bit. We are used
    to external parts from PWM chips. What's the big deal?
  18. Guest
    Yes but with a motor the type of load is normally well defined.(a
    rotating mass of some sort) and is designed for a specific application
    in mind.
    Not so with power supplies where you can be connecting up to almost
    anything.
    I have seen a power supply osicllating once.
    Wab
  19. Guest
    I never said it would - you can read my earlier comments. You
    obviously understand little aboyt control engineering.
    (If it's in a book it's either elementary,irrelevant or wrong!)
    Wab
  20. Some of them do oscillate if you put a large, low ESR capactive load
    on the output for exactly the reason you give.
    DC/DC converter modules suffer from this because they have some fixed,
    compromise compensation that's usually designed for a small capacitive
    load. They ring like a bell when you put lots of low ESR C on the
    output.
    If you're designing the DC/DC converter you can compensate it properly
    for any load, but this doesn't normally apply to the prebuilt modules.
    I first noticed this effect when I started using OS-CON and POSCAP
    capacitors in my designs. These caps have lots of capacitance with
    low ESR.
    A few years ago TI / POLA released a series of DC/DC converter modules
    which have programmable compensation (called TurboTrans), which allows
    you to tune the thing to have good performance for a particular
    (large) C load. I haven't used one yet, but they seem promising.
    It's described in this PDF:
    http://www-03.ibm.com/procurement/p...ibm+06+capacitance+and+transient+06_08_18.pdf
    Regards,
    Allan
