Clifford said:
I didn't say there were many - just that they're available.
That was the fact I was missing - I knew 1/2 CV^2 already - thanks.
Not this little black duck
. But perhaps it's one of those
things that are too hard because no-one's tried
. That's
why I put the question out there for a switching expert to
try to answer, Terry Given perhaps? You out there Terry?
Clifford.
Nope.
I havent studied class D audio amplifiers much. I did read a paper a few
years ago IIRC in IEEE trans. power electronics, which tacked a class D
stage onto a Self "blameless" amplifier, for an efficiency of 90% or so.
I'd just do it that way, the modulator was cheap and the linear
amplifier ends up acting in an error-cancelling role.
I've thought about delaying the audio a fixed amount, and use a (PFC)
SMPS to follow a convex hull of the envelope, the hull geometry and
delay length given by the smps bandwidth. This then powers a linear
amplifier, which has extremely high efficiency because the power supply
rails are always just where they need to be, regardless of the spectral
content.
As the smps bandwidth increases, the hull "shrinks" around the actual
signal. If a quick enough smps can be made, its a hop, skip, and a jump
from there to making a dc-ac converter followed by a linear active filter.
At which point you might try making an actively filtered cycloconverter
Cheers
Terry
