Switching hydraulic solenoid
Discussion in 'General Electronics Discussion' started by dpayne1022, Jul 31, 2012.
  1. dpayne1022
    dpayne1022
    9
    Jul 31, 2012
    I am in no way an electronics buff but we are building an apparatus at work that I need help with. Basically what we are trying to do is have a Vickers hydraulic solenoid automatically switch flow once our hydraulic piston extends and retracts. All i can think of is something with a relay and two switches but I know there are options out there and I have no clue where to start. Any help or ideas would be greatly appreciated. Thanks!
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    How fast does it need to switch?
    A simple 555 timer circuit can be used to switch on and off
    Or you can use a microcontroller for ease of reprogramming
    Relays will probably be needed for when you control the device, I dont know what voltage it operates at but its probably more than 5V so you would need to control it with a relay that can handle more than it runs on on the output side but can be controlled with 5VDC
  3. dpayne1022
    dpayne1022
    9
    Jul 31, 2012
    Well the stroke on the hydraulic ram is 24". What i want to do is, as it extends hit a switch that powers the solenoid and reverses my flow to retract my ram. When it retracts have it hit another switch to switch the flow back to my solenoid to extend it again. This is to continuously repeat until we turn it off ourselves.
  4. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    simple enough, switch to turn it on, a couple latching relays and switches for extended/retracted and youre golden
  5. CDRIVE
    4,960
    651
    May 8, 2012
  6. dpayne1022
    dpayne1022
    9
    Jul 31, 2012
    Any particular switches you would recommend? Also, with the relays, what specs should i be looking for. I'm currently using 110/120v solenoid .
  7. CDRIVE
    4,960
    651
    May 8, 2012
    You didn't answer the question.
