Ok, here's my original concept:
- I need a circuit with LED that the LED only lids when load is present
With some work, I came up with this, please correct if my concept is wrong anywhere:
The R1 is the actual load, it may or may not present, I put switch S1 to clarify so don't bother about moving the switch
In my theory,
I have a +5VDC constant supply
The lower line is the LED, with R2 to reduce current which would be around 15-20mA
The upper line has very little resistant so the current may go up to max of 500mA
Now I want the LED to lid only when the load is present or, in this case, the switch is pressed
So I thought of the transistor and hook it in
I believe the base can not take in high current so I put a high resistor in R3 = 50k and parallel it with R4 which I don't know it's value now and R4 should by very low so very low current goes into R3 just to make the base high and the rest goes to GND via R4
Question:
- Are my concepts correct?
- Can I optimize it?
- With appropriate resistors, will it work? I need as much as 5V 500mA at R1
- If things are fine, what is the appropriate value of R3 and R4?
Since R4 will have a lot of current flowing through, as much as 500mA with 5V, so the power that crosses R4 will be as much as 2.5W and normal resistors are 0.25W, is there such thing as 2.5W resistors? Cost?
I came up with a very bad solution: hook up 10 resistors in parallel to share the current
Question:
- Do I really have watt problem with R4?
- If so, is there any solution to it beside my method?
- Is there a better way to make a circuit that works the way I want??
I know it's a lot but thanks for any and every info
In my theory,
Question:
Question:
