Switchcraft 3.5 mm Stereo Jack Pinout
Discussion in 'Electronic Basics' started by Barry S., Jan 12, 2009.
  1. Barry S.
    Barry S. Guest
    I have a Switchcraft 35RAPC4BH3 3.5 mm stereo jack.
    See: http://www.mailsack.org/swcraft.gif
    Clearly, there is going to be a left, right, and ground for a headset
    and a signal and ground for the microphone.
    However, the jack has 5 pins and I'm a little confused as to what they
    correspond to in a typical computer audio environment.
    _________________________________________________
    Replace 'spam' with 'mail' to reply via e-mail
  2. John G.
    John G. Guest
    I think not.
    It has a ground, And 2 switched signal connections.
    If you look at the plug it has a Tip, a small ring and a larger ground.
    The other 2 connections are switched for switching when the plug is
    inserted.
    John G.
  3. Barry S.
    Barry S. Guest
    Thank you for the response. Would it be safe to assume for a
    headset/microphone:
    1 GND
    2 Left
    3 Left Switched
    4 Right Switched
    5 Right
    Regards,
    Barry
  4. John G.
    John G. Guest
    Bottom posts are generally prefered.
    Try this link for lots of good info.
    http://en.wikipedia.org/wiki/TRS_connector
    Or just google Stereo Connections
    Google is a good place to start and learn lots of things
    John G.
  5. Andy
    Andy Guest
    5 is left, 2 is right.
