Switch to turn on multiple components
Discussion in 'General Electronics Discussion' started by AhmedAhmed, Feb 21, 2014.
  1. AhmedAhmed
    AhmedAhmed
    3
    Feb 21, 2014
    Hello guys,
    I was wondering if anyone new of a switch model or type that allowed for multiple components to be turned on. I have a circuit which contains 2 servos (connected to 2 separate batteries) and an arduino connected to a lithium backpack. If I simply connected the batteries to each device, the devices would be consuming power (at idle) so im looking for a switch that would allow me to connect the 2 servos and the arduino to their respective power sources, in one go.
    Thanks a lot, and appreciate any helpful comments :)
  2. Harald Kapp
    11,826
    2,757
    Welcome to the forum, Ahmed.
    For three sources/loads a 3PST (3 pole single throw) swizch can be used, e.g. this one.
    This one is possibly a bit heavy for a model.
    Another idea is using a relay with multiple contacts (or multiple relays. The contatc side of the relay(s) would switch the power from the battery to the load. The coil is operated from one of the batteries (or the coils, if multipe relays are used).
    Disadvantage here is that the relay will use power while a switch doesn't draw power from the battery.
  3. AhmedAhmed
    AhmedAhmed
    3
    Feb 21, 2014
    Thank you for your reply,
    I initially looked at a 3PST switch but I understood its method of operation as essentially being a single switch with 3 available conditions, rather than a single switch that when turned on, acts as three simultaneous switches. Is this an incorrect interpretation ?
    A multiple contact relay is an interesting proposal, but yes it will need a permanent power supply in order to function.
  4. shumifan50
    shumifan50
    582
    58
    Jan 16, 2014
  5. Harald Kapp
    11,826
    2,757
    A 3PST switch as the one I linked has 3 contacts (see datasheet).
    A lightweight solution instead of the relays could use P-channel MOSFETS:
    [​IMG]
      File size:
      11.1 KB
      176
  6. AhmedAhmed
    AhmedAhmed
    3
    Feb 21, 2014
    Ah okay, once again thanks for the help :)
