switch the brightness of an LED
Discussion in 'Electronic Design' started by [email protected], May 22, 2007.
  1. Guest
    I want to use LEDs in a motor vehicle, but they must be dimmed to
    about 10% of their daytime brightness at night to avoid blinding the
    driver. I need a simple, cheap circuit to do this.
    My thinking was to use a light dependent resistor (ldr) to switch a
    transistor (tr) that then added a resistor (R2) in parallel with the
    LED. This resistor would reduce the current in the existing resistor
    R1 (as it is in series with it) thereby dropping the current available
    to the LED. But would it also change the voltage substantially at the
    resistor/LED junction so that the LED no longer lights?
    +V--\-----------------\
    ldr R1
    | --R2--+
    +---Tr\ LED
    0V---/-------/--------/
    Remember this is in a motor vehicle so there is plenty of spare power
    and heat sinking available.
    thanx, bye.
  2. DJ Delorie
    DJ Delorie Guest
    If you're using a uC to turn the LEDs on and off, can you just use PWM
    at 10% duty cycle? Hook the photocell to one of the uC's ADC inputs.
  3. Guest
    Already run out of I/Os (and code space)
    bye.
  4. D from BC
    D from BC Guest
    Maybe try a phototransistor..
    D from BC
  5. MooseFET
    MooseFET Guest
    Buy a bigger micro.
  6. JeffM
    JeffM Guest
    The *bigger uC* idea sounds apt.
    Alternately:
    http://www.google.com/search?q=LM555+source-or-sink-200-mA
  7. linnix
    linnix Guest
    I have 1 ADC input and 1 LED output (PWMed) in less than 2K (out of a
    16K AVR). I can't find any reasonable uC with less than 8K. How
    small can you get?
  8. linnix
    linnix Guest
    small can you get?
  9. John B
    John B Guest
    This would work better.
    Set RA for minimum LED current and RA//RB for maximum LED current.
    -o-----o-------o----o----
    LDR | | | | RB | | | | RA
    | o--+ | |
    o---| +--| |
    .-. .-. +----o
    | | | | V LED
    --o-----o------------o----
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
  10. feebo
    feebo Guest
    forget resistors to do this stuff... use PWM to make them *appear* to
    be dim... your LDR idea is not the way to go - you have lights on,use
    this to signal to a PIC or similar to switch them
  11. Marra
    Marra Guest
    Why not hook into the lights circuit?
    Thats way you will know if it is dark without a sensor !
    PWM an LED from a simple micro.
    www.ckp-railways.talktalk.net/pcbcad21.htm
  12. Boris Mohar
    Boris Mohar Guest
    How about paralleling a CDs cell across R1? Set the R1 value for night time
    luminosity.
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
    void _-void-_ in the obvious place
  13. Jasen
    Jasen Guest
    here's another way.
    // LED
    input ---------->|----.
    park lights ----[R1]--+
    0V ----[R2]--'
    that may look screwy on your screen, use a fixed pitch font.
    I've never seen a LED damaged by being reverse biased at a low voltage
    (as may be possible with this circuit) but if you're worried add a
    diode in series with the LED.
    Bye.
    Jasen
