Joe
I have a 9V, 0.75A switch mode power supply which has a strange problem. It
does not work (i.e. no voltage output) unless I _slowly_ slide in the IEC
mains lead (so that it sounds like there is some arcing) the first time I
use it for a while. If I just plug in the mains lead quickly or turn on the
socket at the wall it does not work. After it has worked once, and the unit
is slightly warmer perhaps, it operates fine. I can turn it off and on again
at the wall socket with no problems.
Any ideas?
Joe.
Any ideas?
Joe.
