doubledouble
- Jul 16, 2013
- 1
- Joined
- Jul 16, 2013
- Messages
- 1
Hello all.
I'm new here, just registered to be able to post my question. I'm in the process of planning to wire up a few accessories in my car. I need/plan to be using a SPDT switch as part of the project and am having some trouble finding an appropriate switch. I'll be wiring into a 15 amp fuse (could use a 10 A) and assume that I should use a switch that's rated for a higher amperage than the fuse that protects it - is this correct?
Question 2; how can I calculate the rating for the switch in a DC circuit if the rating is given for an AC circuit? For example, I found one switch that looks like it would physically fit the location but the rating is 10A @ 125 VAC. Since I'll be using it in a 12 V DC circuit how can I calculate the rating - is there a simple formula for this? It seems to me that since the voltage is so much lower I should get higher amperage from the switch but the sales assistant at my local supply store thought it went the other way. Anyway, any help would be appreciated.
