Thanks, I've been watching those...kinda steep for just needing the fob
though.
http://search.ebay.com/rs3200
| | > Geez, more dinosaurs.
| > I need a keyfob for Toyota RAV4 2000 RS3200 alarm..just the fob...thats
| what
| > I really need right now.
| > | > | They've got one listed on Ebay
http://cgi.ebay.com/napco-800-825-9...ryZ41969QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
| > | | > | > I still have 2 800's out there that are limping along...the owners
are
| > | > almost out of alternative keypad digit choices.
| > | > > > > I have a Gemini 816 series panel with two keypads model
RP1CAe2.
| > One
| > | > > > > keypad, the main one we use when entering and leaving the
house
| is
| > | not
| > | > > > > working properly, it seems that when we press numbers on the
| > keypad
| > | it
| > | > > > > does not recognize them or I have to press it a few times
before
| > it
| > | > > > > works. I assume after time the keypad becomes worn out?
| > | > > > > How do I change it, do I just buy a new one and replace it or
| are
| > | > > > > there other steps that I need to do first?
| > | > > > > Thanks in advance
| > | > > > > Steven
| > | > > > Also, if you do reach the point that you are changing the
keypad,
| > make
| > | > > > sure that you use the same series. If you have the "K" serries,
| > | > > > keypads, you have to replace the bad keypad with a "K" series
| > keypad.
| > | > > > Or, the original series kepad with an original. You can tell the
| > | > > > difference in that the old series has an ON/OFF button and the K
| > | > > > series has an ENTER button.
| > | > > Thanks for the info. Does this keypad have this happen often that
| > | > > after a few years of use they keys no longer work?- Hide quoted
| text -
| > | > I've been using Napco for about 30 years. Sometimes keypads don't
last
| > | > as long as others. I find that when repetitive numbers are used they
| > | > wear out sooner. If you think about it ..... all you really have to
do
| > | > is pick four new numbers or just change the "bad" number in your
code
| > | > and you'll be ok. Rather than buying a new keypad.
