surge resistors
Discussion in 'General Electronics Discussion' started by ccc, Aug 30, 2011.
  1. ccc
    ccc
    4
    Aug 30, 2011
    hey everyone!!
    i just realised that i ordered surge resistors for my project instead of normal ones. what difference does it make?
    should i run to get the other ones? because this wasn't specified in the schematic.
    thanks!!! :)
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    What is a surge resistor?
  3. ccc
    ccc
    4
    Aug 30, 2011
    humm well.... i would say it would be used to avoid a surge in current in case it happened?
    the question is does it make a difference in a circuit?
  4. ccc
    ccc
    4
    Aug 30, 2011
  5. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Yes, that definitely helps.
    The term "surge resistor" is new to me, and meaningless afaik.
    It's easily confused with other current & voltage surge protection resistors (NTC's, PTC's, VDR's, & fuse resistors).
    The spec's however seems to indicate it can be used as an ordinary resistor:
    Resistance: 39kohm
    Resistance Tolerance: ± 1%
    Power Rating: 250mW
    Voltage Rating: 150V
    Temperature Coefficient: ± 200ppm/°C
    Looking further, into the datasheet, reveals the full story.
    The SG73P 2A is a resistor capable of withstanding 100W pulses up to 10us, and 10W for 10ms, without being damaged.
    So you can safely use it (and abuse it) unless the schematic calls for a fuse resistor (they break easily, to protect other components).
  6. ccc
    ccc
    4
    Aug 30, 2011
    thanks so much for the help!!!! :)
  7. (*steve*)
    25,490
    2,832
    They will work fine as regular resistors.
    As a bonus, if you overload them they have documented performance!
